TwinTurbo.NET: Nissan 300ZX forum - safety boost is there for a reason...
Subject safety boost is there for a reason...
Posted by AntiHero on June 26, 2008 at 3:18 PM
  This message has been viewed 157 times.
In Reply To Re: det sensor bypass seems like the wrong way to go with a posted by gumby on June 26, 2008 at 10:11 AM
Message lets just say you had your cas set to the wrong, and too advanced, timing, or filled your Z up with 87 octane... the knock sensor would detect the knock and put you into safety boost for your own protection.
disconnect the battery and see if you go right back into safety boost or if it works correctly for a moment or a while. check your timing. make sure you are using good gas.
clean coolant temp sensor.
if everything checks out, try det sensor bypass but keep a close ear on it.
Antihero
These 2530's ain't half bad ;)
